1 - 14 of 14 Posts
Curt I need the following:
Drivers side lower fender moulding
Bolts, nut , bushings etc that holds the brake pedal to the push rod
Washer/gasket for where the power steering hose goes into the top of the rack- I think the part number is -44327A
Caster nut for tie rod end
And two brackets on top of condenser- 88718-14090 x 2 I think
The rubber strip that goes across the wiper cowl under hood if its not too pricey.
Do I need to call you or can you go ahead and bill my cc?
Thanks,
Blake Veatch
Super Moderator
90170-10036 Nut, List 0.74 Cost 0.55
90101-10081 Bolt, List 2.09 Cost 1.54
90386-13015 Bush List 1.43 Cost 1.06 Ea X 2
75602-19055 Moulding List 56.13 Cost 41.51
44327-12010 Gasket, List 4.26 Cost 3.15
90171-12002 Nut, Castle List 1.17 Cost 0.86
88718-14090 Clamp, List 7.71 Cost 5.85 Ea X 2
53383-14120 Seal, Hood List 38.53 Cost 28.49
Some Items Special Order. Do You Want To Place This Order?
Okay thanks, Do you have the info on torque specs for those p/s hoses on the rack? I think I might be overtightening, fluid keeps pouring.
Discussion Starter #11
Curt , The bolt/bushings/nut I ordered for the brake pedal are different than the ones I was needing, sorry if it was my fault. I recieved the one that goes through pedal arm where it mounts to the aluminum bracket that it swings on. I need the bolt bushings and nut for where the pedal assembly bolts to the push rod from the booster/master cyl.
Again sorry if it was my fault .
Discussion Starter #13
Okay its 90468-16142
47264A
and I believe 47101A , not quite sure where that spring goes but don't think I have it.
Super Moderator
90468-16142 CLIP list 0.83 cost 0.62
90249-10064 PIN list 4.12 cost 3.04 NS
90905-07004 SPRING, list 5.17 cost 3.83
1 - 14 of 14 Posts
