1 - 20 of 22 Posts
Went to Fayetteville Sunday, hoping for better traction than I have had at Rockingham this year so far.
My first run, I spun when boost hit cause I didnt heat the new BFG's enough, ran a [email protected]! 2nd run, I heated the tires better and ran a [email protected]! Watched the video closely, and realized that the tires werent even turning over for the first 30 ft, that was the reason for two 1.75 60's.
I had the 50HP NOS jets in the car cause I was trying to tune it for a full run, which I decided against, just have the NOS on till boost hits 15 psi. So I swapped in the 56HP jet that I have always used, hoping to wake it up. It did! Next run was a 1.61 60' and I ran [email protected]!
Made two more runs, each time upping the NOS shot off the line, and turned the boost to 29 psi, all the other runs were 28 psi. With a 77HP shot off the line, I ran a [email protected] I only got a 1.63 60', still didnt turn a tire over on the launch! Last run, I used a 94HP shot off the line and ran a [email protected] with a 1.64 60', still not turning a tire over! I expected the extra NOS to smoke the tires! The extra boost picked it up some!
I guess I need to build some boost on the line because the converter isnt pushing it hard enough until the turbos spool-up. I was really trying for a 1.5 60' and a 10.1X! I did top my previous best MPH on every run but one, and ran a new best 60'! Fayetteville hooks great, but is about 1/10 slower than Rockingham, but the 1/4 MPH is the same, go figure!
Al
King of the NA-T's
Congrats Al! How are you launching the car? From your post it appears you aren't building any boost at the line? I found that by building 5-10psi powerbraking, *then* hitting the spray makes the car really jump off the line.
Congrats man! Sounds like you need a 150 shot or so. ;)
Thanks! Yeah, I dont build any boost on the line, just braked to stall speed and used a 56HP shot of NOS, which shuts off with a Hobbs switch when boost hit 10 psi. At the Rock, if I did any more than that I would blow the tires away! I did manage a couple of 1.63's at the Rock.
Not used to a sticky track! I figured going to the 77HP & 94 HP shots would lower the 60' the way changing from the 50HP to my usual 56HP jets did - I also had it stay on till 15 psi. Not real easy to build boost on the line. I can do it if I really try, but it just isnt consistant. If I get on a sticky track like that again, I will though!
Al
Time to hook up a "fuck you Hobbs switch, we're goin 9's" button. For real dude, have a button handy to mash if you feel it leave hard. You know you want to:)
Good times, I thought you'd like those BFG's
They are even the smaller 255/50-16 size BFG's on NA rims.
Oh, I have always had one of those switches to overide Mr. Hobbs! The recommended NOS jets made the car lean when I tried to run it all the way down the track. I have to pick up a couple bigger fuel jets to tune it right next time! :gotnx:
Al
Bad Karma Supra
Congrats man!!
Don't tell me that's the same L10 tranny you have in the car since early last year!?!
And to think all this on those 255/50/16's - gonna step up to the n/a brakes and BIG DR's this winter? ;)
Jay
Discussion Starter · #10 ·
Thanks Ira, I will let you know if I hear of anything.
Thanks Philly, yes it is the same L10! I probably only have around 25 passes on it, and I am easy on the street with it. It works great!
I have no plans to change to the big DR's. I did originally want those 325/50-15's in a big way, but too much involved for the swap - NA brakes, fender & wheelwell mods, coil-overs, etc. Besides, I have a set of ET Streets that I used once, then took them off the rims & swapped in the BFG's. Will probably sell the ET's.
Al
congrats, time for me to take your title with my new dyno number!!!!!!!! Good job al.
vnt ;)
Bad Karma Supra
vnt ;)
Exactly what title are you taking?
T6Rocket said:
Thanks guys! Val, I got 5 different NOS sets, ranging from 50-123HP just waiting in the wings! Seriously, I am going to finally try the 56HP shot all the way down the track, and this time it will be tuned right. ;)
Al
good luck, i thought about nos, but i have my doubts.....but who knows..
vnt
Never enough
T6Rocket said:
I put the NOS kit on it for spool-up only, with thoughts of using it for HP gains if needed! 56HP is not much.
I am using the PI 3800 converter.
Al
Al:
Are you still on stock cams/gears??
Andrew
1 - 20 of 22 Posts
