1 - 20 of 48 Posts
The first time out - with the addition of 264 cams, I ran [email protected] . I knew that I needed more injector than the 680’s I was running – all they could support was 26 psi of boost with the new cams!
I put in 880cc injectors from SP and headed to the Rock Friday night to crank up the boost! Set it at 30 psi, and was surprised I had to add fuel pressure when the VPC/GCC would not richen things up. I thought I would be subtracting fuel, not adding with the bigger injectors! I had been running really rich at 19 psi.
Made two runs – [email protected] with a 1.54 60’, and [email protected] with a 1.50 60’. The runs felt great, but I had small misfires at high RPM’s - I was near 8000 RPM the whole run! I suspect the 82k mile coil packs, even though they check out okay.
Here is the timeslip, video hopefully coming soon!
60’ 1.502
330’ 4.133
1/8 6.343
MPH 110.88
1000 8.252
1/4 9.875
MPH 137.09
Thanks to BCSupra for all his help at the track, and HotSoup was there running 11’s in his auto BPU Supra.
On a side note, Phillip Long was also there in his Syclone truck. He ran [email protected], [email protected] and [email protected] at only 25 psi on his new motor!
Al
Al, Congrats once again!!! Very NICE runs. It was amazing to see you blast through while I was at the 1K marker watching!
Later,
Jason
Congrat's on your new times , Very impressive 60ft's.
Albert
You're quite welcome for the help, buddy. The T6Rocket was definitely movin' out!! Very impressive passes, and I know there's more in her. Hard to complain with results like that from a 5 minute tune though. haha ;)
Congrats Al, to have one of the cleanest and stock appearing cars running 9's is simply amazing. The other part of the story is this is NOT a trailer'd car, Im not even sure if the man owns a trailer or not. It is driven to and from the track!
Congrats again, next time maybe you can talk brian into running!
Al,
I'm so jealous.....Congrats Bro!!! I really need to fine tune my shit and hit the track.
vnt ;)
Discussion Starter · #15 ·
Thanks guys!
I recently switched to M/T ET Street Radials. I think they are better than the BFG's, but I did cut a 1.49 with the BFG's last year. I am still running the Level 10 trans with a 3800 stall.
I think the MPH was a little low from the misfires, might be time for new coil packs!
Al
Congrats Al!! Maybe you don't need a new manifold after all? :D
1 - 20 of 48 Posts
