1 - 2 of 2 Posts
Titan Motorsports' NEW Billet front covers for dry sump 2JZGTE engines are here!
245984
The Titan Motorsports 2JZ billet front cover is CNC machined from 7071 aircraft grade aluminum for increased strength over the cast factory, alleviating common failures seen in our nearly 2 decades of racing. Using computer aided design we have increased material thickness and strengthened key areas of the cover for the increased stress loads applied to the tensioner and tensioner bracket preventing the timing belt from losing tension. This cover combined with our Titan Motorsports billet tensioner bracket and hydraulic tensioner delete provides for the ultimate combination to keep the engine in time and your valve train safe.
Do to the removal of the factory oil pump with this unit, it is designed for race use only on engines with external dry sump oiling systems only.
1 - 2 of 2 Posts
