21 - 40 of 60 Posts
Rejoined
^^That answered my question about the EMU Black. Thanks.
  • Like
Reactions: NOLAGG
Discussion Starter · #22 ·
Just ordered the s23 manifold and made up my mind I’m going to go with the gtx3582r gen 2 .82 t4 . I mean how much different is the g35 serious turbo ?
253472
253473
Discussion Starter · #23 ·
Was originally going to hook up the greddy boost cut defender along with the innovate wideband /boost gauge in 1 , but realized I don’t really want to cut into the stock obd2 harness since I already ordered a new wiring specialties harness for the emu black
Very nice find. That's the exact color combo (red exterior/black interior) I'm looking for. It would be perfect if it was a hard top. Is that a 97? I came across an excellent conditioned red/tan combo at a dealer but they're asking too much imo. And funnily enough, I used to have a 350z as well (03 brickyard).
I've got a few questions for everyone:
  • If you plan on cleaning the engine block/head, is ultrasonic cleaning ideal or is hot tanking more than sufficient?
  • Prior to wrapping exterior body parts, should you wait a certain period after repainting or clear coating parts?
Discussion Starter · #28 ·
Yeah probably a few months since the clear has to cure /breath for a while hence the reason why they tell you or to wax a new paint job for atleast 3 months from my memory
Discussion Starter · #29 ·
UPDATE!!!!!! So it’s been a while guys but I’m back .
a lot has been done even with the garage and setup in the little garage I’m currently working out of for the time being .
laid some husky interlocking floor tiles and let me say helped control the dusty crummy pour the guys who built the house laid down and also looks sick .
So last month I pulled the motor did a full refresh on everything , painted block and pans and scrubbed everything down super clean . Changed all gaskets , re sealed everything , changed steering rack bushings and still have a few more things to go .
Tire Wheel Vehicle Automotive tire Motor vehicle
Stairs Automotive design Wood Interior design Floor
Automotive tire Motor vehicle Automotive exterior Gas Bumper
Circuit component Asphalt Rectangle Road surface Gas
Discussion Starter · #31 ·
After it was all torn down the first thing I wanted to tackle was the valve stem seals . Replaced those with some gsc valve stem seals and did the BC springs and retainers utilizing stock usdm cans and valves just for future .
Discussion Starter · #32 ·
Started to drop the pans for a reseal and cleanup and also painted the block and scrubbed every inch to make it as clean to my ability . Threw the phr cam gears new seals and belt on with a bunch of new hardware as well as a new oil pump water pump ect .
Discussion Starter · #33 ·
Welded the water neck shut, threw the hot side on just to get a look at the future powerplant lol.
Discussion Starter · #34 ·
Threw the phr triple in with a 450 primary and 550 secondary along with McLeod twin disc setup with the tilton master and release bearing
Discussion Starter · #35 ·
Threw the motor in and here is where we are . Snaked the wiring specialties harness in the cabin , ran vibrant ptfe fuel lines , now I’m going to throw the trans in tonight by myself . Didn’t realize how wobbly the motor is with just stock new 96”7 mounts with no trans attached .
Super Moderator
Very nice work! Very thorough as well. I have the same PHR E-85 set-up in my red car as well. Down the road, I need to look into those Husky interlocking tiles as well.
ken.
Discussion Starter · #37 ·
ken.
Thanks Ken, have to modify the phr fuel pump cover holes as the fitment is just way to tight , snake the vacuum hose threw the harness boot
(which I forgot ) from cabin to engine bay for emu black , make the rail to filter 8an ptfe line and then throw the rest together . First thing though is I need to get this trans in and boy what a pain in the arse it is . Didn’t have enough height to install it attached to the motor unfortunately so now working on getting that done tonight with a buddy because I was unsuccessful doing it alone last night and the harbor freight trans jack was useless as I can’t gain enough height with out the actual jack pad hitting the tunnel being too big for this chassis
Discussion Starter · #39 ·
Looks incredible! Tons of work, but the payoff is amazing. 👍
hey thanks brother , not perfect but definitely came along way . Hopefully getting a ton done tonight . Trans is in , going to bleed the clutch , install drive shaft , finish fuel lines and start bolting all parts in
21 - 40 of 60 Posts
