1 - 20 of 27 Posts
Well I recently descided to put a very large sum of money into the Supra. So far I have collected:
Walbro 255, 550cc RCs, Lex AFM, PWR rad, Spearco intercooler, Greddy type-s, ceramic coated hard pipes, Spec stage 3, RPS flywheel, Ross pistons & rings, Pauter rods, rebuilt head, ARP hardware, ported exhaust mani. . .
http://i3.photobucket.com/albums/y62/Gilsdorf/IMG_1026.jpg
http://i3.photobucket.com/albums/y62/Gilsdorf/43bdd54a.jpg
Current mods are as follows: K&N fipk, apexi avc-r, Greddy SP cat back, HKS dp, cross drilled rotors F&R, ss brake lines, F&R strut tower bars (GREX), ROH drift-r 17x8 . . .
http://i3.photobucket.com/albums/y62/Gilsdorf/635aff3f.jpg
http://i3.photobucket.com/albums/y62/Gilsdorf/9b40fe6f.jpg
Waiting on the machinist to finish the block, still debating about the turbo (sp61, full TO4, or other).
Yet to order: SAFC, AFR, sway bars, bbk, new seats.
badass man, i wish i had the money to order that much stuff for my supra. car looks great
Chris Dickens
Sounds like a good list. Let us know what you end up deciding with the turbo. Should make some good power, but it seems that money is no object, so instead of Lexus and 550s why didn't you go with a MAP ECU, or a VPC (if you could find one)?
512RWHP... 503RWTQ... 7M
I just think it's sweet to see someone who is actually investing the money in go fast, stop fast, and run good parts... Good job...
Ditch the Greddy Type-S. You will understand why if you actually decide to put it on the car. Get a HKS or Blitz. Many many people have had problems with the Type S (I went through 3 myself). Good list though. Good luck with putting it all on.
DAMN u a big one lady
Get rid of the HKS DP and get a BIC DDP, add some serious power. Everything else looks good bro. Good luck
I Didn't Do It!
hes upgrading the turbo so unless he goes SP61 BICDDP is pointless, as it's made for the ct-26(correct me if i'm wrong)
desufnoC
What problems did you have with the Type-S?
yah, hearing that about the type s is a first for me. The only complaint I have is that there is no o ring on the piston shaft, so when the lower nipple is hooked up like it should be ideally it leaks boost.
Stock Boost SUX
You sir are correct.
Most turbo "kits" come with the DP, but if you dont buy a kit, you'll need a custom DP.
Discussion Starter #13
Thanks for the feedback, I've never heard of the type-s leaking but my end up going with the type-r if I run into any issues. The pipes have the Greddy flange already welded on and have been ceramic coated.
Afew other things I forgot to list: tokico Ill II's with eibach springs, genuine Toyo bearings (coated), jethot coated exhaust mani and shields, Swain coated tops and skirts, Bomex three hole (in the third level of back order hell), Cometic/Titan HG.
It's late and I've probably forgot some other stuff, but you get the jist of the quality of vehicle I'm building.
Take it!
damn, thats sweet! I wish i could order that many parts for my supra! Good luck with the upgrade man!
I had three Type S's on two different turbo setups. Greddy kept replacing them for free for me, so I kept using them. They kept failing and kept not working. Either leaking boost or not opening at all and causing turbo problems. They never worked.
If you already have the Greddy flange on there, get the HKS Racing Bypass Valve. It's not the 400 dollar HKS Racing BOV, it's the Racing Bypass Valve. By far my FAVORITE one I ever had. I sincerely regret ever having gotten rid of it. And coincidentally, it has the same flange. You will like that one a lot better and it's as cheap or cheaper than the Type S. It held over 20psi and 450+ rwhp for me.
Big HP = Big Downtime
is the greddy rs ok? I just bought one im installing soon...
My bad. I missed seeing that part about him upgrading the turbo.
Not ur jizz, not ur bizz
almost..it hooks up to an SP61gt as well.
however, id go full out external wastegate 35mm Tial or somethin.
Moderator, l337 M0d3r4t0r
Damn nice set up... you have the parts for a monster.
1 - 20 of 27 Posts
