1 - 4 of 4 Posts
TC Motorsports
Clutch Problem
Okay installed a new RPS stage 3 clutch and flywheel into a 94 TT Supra. The clutch engaged correctly so I did not need to adjust the pedal. Drove the car around and every time I put the clutch in the car died. Restarted the car and this kept happening. Finally died out and would not start. I went though all of the possible solutions thinking it was the alternator not charging the battery. Is it possible that the clutch is engaging too tight and killing the engine? Then by me trying to restart it over and over the battery is being drained out more and more? I have never had this problem before, I have had the clutch not engage fully but not engage too much and kill the car. Nothing else was touched except the clutch.
I have ruled out the alternator.
TC Motorsports
Discussion Starter · #2 ·
Mods please delete this thread
TC Motorsports
A combination of different problems. I was so pissed that I could not find it I stayed out in the garage until I did. Loose ground wire on the alternator, low battery charge, and the clutch pedal needed to be adjusted.
1 - 4 of 4 Posts
