·We have finally finished designing this new turbo, and now here it is... It is called the T90, it features compressor and turbines wheels similar to that of the T76. The wheels are slightly larger to accomodate for the extremely large housings that have been designed to support between 600 and 1200+hp!!! The housings are similar to the size of the Thumper series turbos from Turbonetics. It also has a divided tangential T04 bolt up exhaust flange so that it will fit most of the manifolds available. Here are some of the specs on it...
Compressor-
Inlet 5"
Outlet 3"
Inducer 3"
Exducer 4.25"
Turbine
10 blade
Outlet 3.5"
Wheel Diameters 2.75" and 3.25"
The turbo will sell for $1800, it comes with a full warrentee and can actually be returned if you are not happy with it, as long as it is not blown. Here are a few pictures of it, for reference, the turbo on the right in the two pictures is a T3/T4 with .60 compressor and a .63 exhaust. Contact Chris Forsberg at [email protected] for any other information regarding the turbo.
Compressor-
Inlet 5"
Outlet 3"
Inducer 3"
Exducer 4.25"
Turbine
10 blade
Outlet 3.5"
