With all the wheel questions, I thought I would get more responses. Can everyone figure out how to use it or do I need to put it in a different format?
Your expertise has been invaluable,but cannot get to your web site. Would you mind emailing direct to; [email protected]. Appreciate your help. You didn't say if you got it up on MKIV?
Thanks for the e-mail steve. I was wondering , when you list an ideal offset does this offset vary by wheel type. That is, does the type of face or style of wheel influence the offset.
The style of wheel doesn't affect the offset. It does affect things like the width of the lip and whether or not the wheel will clear your brake caliper, but not the offset,
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
Recently acquired a rhd supra and slowly starting the process of swapping things over. Got myself some glass headlights and wanted to swap bulbs while I’m at it. Been told jdm lights differ from usdm. Hard finding more info on this. Thoughts? Trying to find a quality hid system, seems LED isn’t...
I came across asking myself today, do you need a igniter when you go to a aftermarket ECU and Harness? I noticed my friend is running a MOTEC and does not have one for his car.
Hey guys,
Just installed a pair of S2 taillights on my 93 Supra RZ. I would like to convert to LED. I would like to purchase from here as the prices seem very good.
https://www.superbrightleds.com
According to my search in the Forums, looks like I need 2 x 7440 and 2 x 7443 bulbs Just not...
Hey guys,
I had a boost leak on my 94 BPU for years and didnt notice it because I still got good boost. So I finally fixed it but forgot to turn my boost controller down. I hit 25 psi 2 or 3 pulls without realizing it. Since then it wont go much over 14 psi anymore.
I did a boost leak test for...
