1361 - 1380 of 1427 Posts
A 305 will be too tall and have a chance of rubbing. You'll have to step down to a 295/30/18.
R.K.
Alright Rad!
R.K.
Alright Rad! I was scrolling through this forum and came across TrevorSellers black Supra w/ VS-XX in the specs
Work Wheels VS-XX
Falken Azenis FK510
F: 18x9.5 +35 265/35/18
R: 18x10.5 +45 285/35/18
That’s the wheels Im going for and I read that he could’ve gone a little wider according to you(Work rep said to go 10.5 to be on the save side) What specs should I get for the rear to fit my stock supra(no fender roll Or cut)? If I were to run 18x11 what tire size should I run? And what type of disc should I get for front & rear with Supra TT 4pot brakes? Thanks so much for you help. Hope to hear from you soon.
Wheel Fitment Guru
Alright Rad!
Work Wheels VS-XX
Falken Azenis FK510
If you went with the 11" wheel on the rear, the 305 is the tire that fits square on there. Problem is its too tall. The 315, 295, 285 and 275 tires are all proper OD.
R.K.
R.K.
Hey Rad. Would I be able to run +42mm in the back without rubbing on my stock rear fender or is +45mm the max size? I’ve read through is forums and guys been saying to run +45 to +50 if I don’t want to rub.
You will rub with stock fenders. Go with an 11 +48. I run 11 +42 with the fenders shaved flat. I highly doubt a +45 would work with the stock fenders.
Casper
Verstuurd vanaf mijn SM-G950F met Tapatalk
Dayum, those numbers are sure some gnarly, fat, strong tires..... Stuff of my dreams right there. @JGBalticMK4 @CasperMK2
Sent from my SM-N960U using Tapatalk
Wheel Fitment Guru
Casper
I would agree with Casper. I would even go more conservative and go with a +50 to +52. A +48 will only come in 6mm. Not enough to clear the lip safely.
R.K.
R.K.
R.K.
Since 18x11 is pushing the limits of stock rear fenders I’ve decided to go with VS-XX in a 10.5 +45 would clear the rears right? And what type of disc should I run in the front and rear if I’m only upgrading to TT 4 pot brakes?
Wheel Fitment Guru
18x10" +42 T-disk on the front
18x10.5" +45 A-disk on the rear
R.K.
275 front and 285 rear.
R.K.
For the works VS-XX
275/?/18
285/?/18
I also have stock NON TT JDM 16” wheels.
What’s the largest tire size I can run for these? They originally came with 225/50/16 and they look way too small.
would 275/45/16 Rear 255/45/16 Front be ideal to have a somewhat meaty look or would they not look proportional?
Thanks so much for the response as always Rad!!
Wheel Fitment Guru
For the works VS-XX
275/?/18
285/?/18
275/35/18
285/35/18
No idea about the 16" wheels as I don't know the widths of them.
R.K.
I’m looking into getting some BC forged wheels. Had a couple of questions.
I want 18x11.5 rears. Fenders cut. So 315/30/18 tires.
What front widths are people running with 11.5 rears? Do I need to go with 18x10.5 or 18x10? Is it purely preference?
Then I’m not sure what tire size to run on front for either.
Wheel Fitment Guru
Then I’m not sure what tire size to run on from for either.
10" fronts and +42.
R.K.
Wheel Fitment Guru
What tire size is preferred up front? 265/30, 265/35, or 285/30? I feel like I’ve read people using all three
Either a 275/35/18 or 285/30/18. It all depends on the rear tire size you're going with and whether or not the tire will have a stretched look.
R.K.
Hi guys. Any recommendations on tires with a rim guard, all season? Looking to get 285/30/19 and 245/35/19. Hopefully there will be Black Friday deals coming up for the holiday on tires.
R.K.
Rears will probably be 315/30/18. Wanted as much meat as possible
Hi all,
Looking to order a set of XXR 555's in the following sizes.
Front: 18x8.5 et35 or et25
Rear: 18x10 et25 (only available offset)
Will the rears fit with non-rolled fenders? I would like to keep the body stock. And would et25 fit on the front or is it wiser to go with 35?
