1401 - 1420 of 1427 Posts
Yea...I removed them after a test fit. Anyone know of any nice used Supra fitment wheels?
Heh, funny you should ask ...
275/35/18
285/35/18
No idea about the 16" wheels as I don't know the widths of them.
R.K.
Hey Rad!
So I just acquired a set of TE37 OG MK4 Spec
Fronts - 18x9.5 +40
Rear - 18x10.5 +45
I currently have stock suspension but I just recently acquired a set of Eibach Pro drop springs and I’ll be running that with the KYB AGX struts Would I be able to run these tires?
275/35/18 - Front
315/30/18 - Rear
I’m looking for a meaty look and I figured these would give it that. Any help would greatly be appreciated. I’m not looking to roll my fenders. Thank you.
Wheel Fitment Guru
Hey Rad!
Fronts - 18x9.5 +40
Rear - 18x10.5 +45
275/35/18 - Front
315/30/18 - Rear
The wheel size and offset are good for no fender mods. Also, 315's have no business being on a 10.5" wheel.
R.K.
R.K.
As always, thanks for the reply Rad!
What’s the largest tire size I can run on this specific wheel spec? And any specific tire recommendations you got for me to have a little meaty look to the wheels? Thanks in advance for all the help.
Super Moderator
Your wheel is 10.5 inches , or 266.7 mm wide. A 275 mm width tire will fit, but a 285 mm tire will look better, IMO, and give you the look you want. I have 10.5 inch wide wheels on one of my cars and Michelin Pilot Super Sport tires, sized 285/35/18 mounted on those wheels.
Ken.
  • Like
Reactions: Radride and Mr.Gill
Hey guys,
What do you think of:
Advans GT
Front : 18” x 9.5 +22 on 265/35 on triple 8s
Rear : 18” x 10.5 +22 295/30 on triple 8s
Someone posted on FB and said they don’t have any issues with rubbing and no cutting fenders. However, the tires are about 1” larger than the wheels.
Here is a pic:
I can assure you they will rub if not rolled, at least, those are my exact specs for rear... And yeah, rolled and minor cut.
Probably the guy selling it doesn't know that his fender is cut or not, maybe the previous owner did it or something. Just my 2¢.
Looks hella good, though
Rishi
Sent from my SM-N960U using Tapatalk
  • Like
Reactions: Radride
Wheel Fitment Guru
Hey guys,
Advans GT
Here is a pic:
He’s lying to you. That car has been to the body shop before. It’s been modified to fit.
R.K.
Ken.
Thanks so much for the info Ken. Would I still be able to run 285/35 tires if I install the eibach drop springs which lowers the rear 1.2”?
Your post caught my attention since your rear wheel sizing is same as my Veilside wheels, 10-1/2" +45 on which I have run Nitto NT05's in the 285/35 with no problems. ...edit: forgot to say mine was also lowered about that same 1.2"
259470
Will I have any issues with this setup? I’m on BC coilovers rears are rolled. Also what’s a good tire size with these. Thanks.
That’s great to hear! Just waiting on a few more OEMparts for the suspension and I’ll get them assembled! Will keep you all posted. Thanks so much for all the help guys! I truly appreciate it.
Avid av06 wheels, which offsets out of the following would require no cutting and will clear stock TT brakes? I want to run 245/275 tires. Thank you.
18x8.0
5x114.3
+35
18x8.0
5x114.3
+42
18x8.5
5x114.3
+35
18x9.5
5x114.3
+18
18x9.5
5x114.3
+24
18x9.5
5x114.3
+32
18x9.5
5x114.3
+38
Need wheel guru input. Car is lowered on coil overs and front and rear wheel wells are not touched. Can I get away with 11 inch rears without trimming the fender lip? Also tire size recommendation would be appreciated.
Work Meister S1 3P
Front
19x9.5 +37
Rear
19x11.0 +45
Wheel Fitment Guru
18x8.0
5x114.3
+35
18x8.0
5x114.3
+42
18x8.5
5x114.3
+35
18x9.5
5x114.3
+18
18x9.5
5x114.3
+24
18x9.5
5x114.3
+32
18x9.5
5x114.3
+38
Question, why would you go small when you can probably get better fitting wheels for the same money as these and will be able to run real size tires. Plus, I can't guarantee these will clear the front turbo brakes.
R.K.
Wheel Fitment Guru
Work Meister S1 3P
Front
19x9.5 +37
Rear
19x11.0 +45
The fronts will be fine. The rear is close to flush fitment. Unless you're running a really skinny rear tire, they will rub.
R.K.
