·I've got a 90T 5spd w/ JDM 7mgte swap in it, HKS metal HG, lex afm, full 3" exhaust, 3" downpipe, stock cat (
for now...) and i had some questions about where to go from here...
Firsly, from what i have gathered it is a BAD combination to run the lexus AFM w/ stock 440cc injectors and 550cc injectors seems to be the best combination...but i have plans for bigger horsepower and an e-manage (i also have an e-01, not installed yet) I was wondering if i should stick with the lex. afm & 550cc combo even after i put an e-manage in...or if i should go with something a bit larger, such as 680cc or 720cc. I also have a FCD and i was wondering if that is going to do anything for me since i already have a lex afm.
My eventual setup will be:
e-01, e-manage, test pipe, FMIC, 60-1 turbo (w/ mani. and external wg, of course) ???cc inectors... 255lph fuel pump, better clutch, radiator, elec fans
I'm thinking with all of that i should be able to hit 350hp without too many problems...but just a couple more questions...
What is the best clutch for the mkIII able to support 400+ hp, what is the best radiator able to support the same amount, and is there anything i'm leaving out that you think should be included?
thanks!
jb
thanks!
jb
