hi :) im currently looking for a 98 supra rz
me and many other supra newbie owners have questions..
1) what is good about Twin turbo ?
2) why do people convert to single turbo?
3) I've head it's Really easy to pull 500bhp from a supra for just $2,000 ? but what about 900hp? i wanna create a supra Drag and track racer.
Thanks heaps for your help guys :)
i appreciate your help with a supra newbie like me :)
your comments are welcome! :)
- Sammy :D
Acura Driver
Sequential twins like on the Supra are good because they can provide a more linear power delivery/boost curve than a big single. The first turbo (smaller than the second) spools earlier and provides boost in the mid rpm range. The second turbo, which is a little larger than the first, spools at a higher rpm, but is able to provide more boost than the first.
People convert to a large single because they are able to deliver much more high rpm boost and power, even if they do not spool as quickly.
You will definitley want to learn a lot more about the car before you just go buy one and turn it into a "drag and track racer"... which are somewhat mutually exclusive by the way. 900 hp is neither easy, nor cheap, and involves much more than just slapping on a T-72. Good luck.
NSW supra club Member
Hmmm....i believe BOTH the turbos are the same size(both the first and second turbos).
The first one comes in first,and then at about 4000rpm a valve/flap opens up and let some gas flow to the second turbo making it start spinning,causing a boost rush at about 4200-4500rpm,thats why it feels like the second turbo is bigger but its not.Its just that there are 2 turbos now on full blast,insted of one.
The sequential system i think is good for the city and very zippy around town,with not much lag,but if you want a drag car,then a big single will be the way to go.
You can go bigger twins,but then youll still get lag and pay twice as much then for a big single but have about the same power.
Retired Admin
BRKNDLW said:
Mazman,
I don't mean to sound ignorant or rude, but what's the advantage(s) of upgrading to a big twin setup if if the single big turbo does an equal job???:p
Kind of like buying the Lexus Land Cruiser over the Toyota model, even though they do the same thing.
Maybe just the security of knowing?
Honest answer...
Brittany
Acura Driver
Hmmm... I must have been misinformed by someone then, I apologize. Remember that I'm relatively new to supras. In fact, it seems to me that there is somewhat of a shortage of readily available information on the car. I've done a good bit of searching. I know with the Z, it is exceptionally difficult to find information on the actual garrett specs of the stock turbos, such as compressor maps, etc... I don't know if any such difficulties exist with any technical aspect of the supra.
So if anyone could point me to the resources, I would appreciate it. :D Thanks.
