1 - 12 of 12 Posts
CT12 Destroyer
I was out today just driving around and all of a sudden I let off the gas and was at ~2500 -2600 RPM my car started studdering and popping, and did a little jolt. Almost like a premature fuel cut. I've hit fuel cut before and it was way too soft to be that. My SAFC is set back at 0 to avoid any problems until I get on the dyno and tune it .
Plugs are good, Injectors are good, Ignitor is good..
Any insight ?
Super Moderator
compression test?
CT12 Destroyer
I wasnt thinking compression, But I'll do that this weekend.
And as far as map, I'll swap it out with my spare and see what happens.
EDIT: Will a Knock sensor do this ? :ugh2:
turbo....................
When i had a bad KS, it only did it when i gun it. The car would retard itself and it studder hardcore.
CT12 Destroyer
Discussion Starter · #12 ·
A bad SAFC setting and a cracked line to my Map.
Replaced the line, put a small clamp on it, Fixed my SAFC settings and runs good.
1 - 12 of 12 Posts
