1 - 9 of 9 Posts
60 footing
is there a map show colored wires how to hook the nitrous to the aem other than this picture ???
60 footing
the guy whos working on my car didnt understand that picture altho hes good at electronics
Carma Performance
The picture LOOKS fine, but the numbers on the relay are wrong. 30 should be at the bottom(12v in), 87(12v out to solenoid) at the top, and 85(ground trigger from ecu)-86(12v in) on either side.
Just make sure your switch can handle at least 20 amps.
Premier Tuner
Exactly, also don't forget to put a fuse in between the battery and relay.
1 - 9 of 9 Posts
