Nitrous
715 Views 6 Replies 3 Participants Last post by  supratt320
Greetings from the UK.
Seeing as how I'm picking up my 94.5 TT 6-speed on saturday :D (nope that grin isn't anywhere near big enough), I've been scouring the web for info on upgrades and came accross these forums!
I have a couple of questions about fitting a nitrous kit (still rare in the UK). I was wondering what size shot would be safe for a BPU car. Would 100hp be ok? what would you recommend upgrading to be able to go up to 150?
Any recommendations/tips/stories would be greatly appriciated!
1 - 7 of 7 Posts
NOS has a wet kit good to 100hp
A dry kit for 100hp+ or you can go to
www.powerhouseracing.com for their direct port kit good to 1 billion hp.;)
Im pretty sure you have your Wet and Dry switched around:)
ummm actually they are both wet kits see the red solenoids in the direct port pic? those are fuel solenoids when you spray fuel in with the nos its called a wet kit.
one is sprayed into manifold with fuel= wet
one is into combustion ports= dry
But technically N2O needs fuel to work so i guess ALL N2O are wet kits. Jeeze.
50 or 75 shot will be safe. Well, as safe as it will get. If you want to go above a 75 shot, I recommend doing a direct port setup. Get the wet kit. Wet kits are the ones with a nitrous and a fuel selonoid. Get as much safety equipment as possible.
Long,
1 - 7 of 7 Posts
