1 - 12 of 12 Posts
Thanks for the reply. I know the tire will fit, but I don't want it to bubble out to much. I'd still like to hit a corner or two without having to worry about the tires. The 275/40's work great but I want to fill my fender well a little more :cool:
ive always heard an 11 inch wheel is the correct width for 315s, but since the Nittos are known to be slightly skinnier than they are rated like you said, I would say you could probably get away with it with 10 inch wheel.. But i would hate to tell you I know for sure it would work without much bubbling and have it not work out for you. hopefully someone with actual experience with a 315 nitto on a 10" wheel will see the thread.
Lets go Nets
i heard the nittos run smaller than they actually are.. on a 10" rim, why not run a BFG 275/40 Drag radial?
Brett
BFG's are the oposite, I've found their 275's to be under rated:D I took one of my BFG tires and lined it up next to a 285 street tire and the BFG was wider.
I use to run BFG's but they are highly unstable on any corner in my opinion. I will stick with the Nitto DR's :) I can still hit corners and have great straight line traction.
Lets go Nets
yea if your running daily driver tires, i would stick with the Nittos. they can do everything a regular street tire can do!
Brett
I would not mount a 315 on a 10" wheel. I have seen a Corvette with 315's on the stock 9.5" wheel and it look really bad (as in not good). :)
Later, Steve
Discussion Starter · #10 ·
Later, Steve
Steve I've seen the same thing. The tires bubble out like no other, however, Nitto 315's are not true 315's and thats why I'm asking.
I guess no one is running Nitto 315's on a 10" wheel :(
1 - 12 of 12 Posts
