1 - 3 of 3 Posts
Or is it must be done from the bottom?
I looked at the engine bay today, it seems impossible to reach 1 of the 2 bolts from the top.
I'm getting a downpipe installed in a few days, maybe I should attempt from the bottom?
do you have to replace the bolt with a longer one?
What mod do you mean exactly? ….. adding spacers to the bracket that holds the EBV actuator to increase transition boost on #1 turbo alone? That bracket mounts on to the #2 turbo housing at the rear of the engine bay. Is that what you mean?
I can't imagine doing it from above, but I have done it from below. With the DP out of the way, it is challenging but possible, and small hands help. I can't remember for sure if I needed different bolts or not.
Yea that's what I'm looking to do. I guess I'll do it when I change the DP later.
1 - 3 of 3 Posts
