After i took off both front wheels and checked for leaks everywhere on the lines and calibers with soapy water no leaks i could see. But i did notice the the driver side caliber is missing the bleeding pin hole. the passenger side had it. Could this be the problem?My wifes car did the same thing. It was a pin hole in one of the front caliper brake lines. Had to pump it about 20-30 times to see the actual leak. Just so happen to be the last wheel to bleed...
:nuts:with soapy water no leaks i could see.
before i used the soapy water i looked and it did not show any leaking.You don't use soapy water to check for fluid leaks... Just look for wet spots. If the ball is missing out of the bleed screw or the bleed screw itself is missing then yes you will have 0 brake pressure.
