Car ran great the first weekend I got it up and when I took it out the next weekend I started having these limp mode type issues that are driving me crazy. The car idles sub 10 afr like a bag of balls and hesitates to rev. (Aristo swap, single turbo , stock fuel aside from a SAFC and no check engine light). Tried a 2nd ecu, replaced map sensor and bunch of other little things but nothing has worked.
After catching another thread I decided to test my coil packs by unplugging them one at a time. Here were the results numbered from the front of the engine bay to the rear:
Unplug coil 1: Car runs shitty(er) and immediatly runs better when plugged back in.
Unplug coil 2: Car runs shitty(er) and immediatly runs better when plugged back in.
Unplug coil 3: Car runs shitty(er) and immediatly runs better when plugged back in.
Unplug coil 4: Made no difference in how shitty the car was running.
Unplug coil 5: Made no difference in how shitty the car was running.
Unplug coil 6: Made no difference in how shitty the car was running.
Then I decided for the hell of it to unplug 4, 5 & 6 at the same time which stalled the car immediately upon startup. Then any combination such as 4-5, 4-6, or 5-6 made the car stall just the same. THEN I tested each cylinder for spark and there is good spark on every cylinder.
WTF is wrong with my car? I am tired of spending money chasing this issue around.
---------- Post added at 04:48 PM ---------- Previous post was at 04:40 PM ----------
On a side note the nice folks who did my harness suggested a general grounding or specific coil pack grounding issue. The 2jz coils are grounded to the engine I assume being bolted to the head?
Also where did you guys do your engine grounds. I'm sure I'll miss one or two that I have but these are mine:
1. Firewall to rear coil pack
2. Firewall to rear tow hook
3. battery to body
4. bellhousing to body
5. tranny to trannymount/body
I can't find a good place to bolt directly to the head.
3. battery to body
