1 - 1 of 1 Posts
Search
I just did a compression check and replaced the spark plugs... now I'm replacing the fuel injectors. When I did the compression check I pulled the EFI fuse and just cranked for 7 seconds.
I just undid the line on the fuel pressure regulator and there was NO fuel... is that normal? I had the fuse out when I did the compression check so shouldn't there still be fuel pressure in the rail?
1 - 1 of 1 Posts
