1 - 18 of 18 Posts
Ive finally got my car up and running.... ive noticed that i have a flat spot in the power band. If im in 3rd or 4th gear and stomp on the throttle, the power comes on linearly until i hit 7-8psi and feels sluggish all the way up to around 14-15psi, once it passes that point, it seems to pull properly again. I had this problem with my stock IC pipes, so i upgraded to Cooleeze hardpipes. Ive also changed bov's. Neither of these corrected my flat spot. The gauge is reading correctly and the boost needle rises properly. I can actually hear the air being ingested but no power. If i start in 2nd gear, it pulls like a mofo and feels strong through 3rd gear. My timing is set to 10degrees, my AFPR is set to 38 psi base pressure. Also, no codes.
Here's my setup:
Exhaust
DP
Testpipe
Intake
550's
Lexus AFM
SP61GT
AFPR
Would a bad 02 sensor be the problem? I do notice my street driving mileage is around 12mpg. The car holds boost at 17psi. Any ideas what the problem could be? Thanks
O2 wouldn't affect WOT power, but will cause that crappy mileage.
Go to a dyno and check AF's, and check your TPS- That's all I can think of.
i agree with above, get on a dyno and see if the flat spot really exists and if so check your afr in that area. what you use to control fuel?
i bet you are running really rich in that range, get on the dyno and see if a good tune takes care of it.
if you havent tuned and you have 550s....your running crazy rich probobly.....like everyone said get on the dyno and that should take care of the problem
Discussion Starter #9
its possible, probably not though. i had the problem with stock pipes, and now that ive upgraded to hardpipes. id really doubt the leak would still be there or at least exhibit the same exact problem.
Fatty McFatty pants
I passed by your house today messing testing the shimmed turbo and how much it'll hit up to, sorry for hijacking your thread, maybe you heard my bov going off a few times :rolleyes:
Hardtop FTW
I'm going to go with the crowd and say get it tuned. It sounds like an A/F ratio issue. Good luck!
BMM
^ :werd:
BTW, did you ever fix yours RTA??
Discussion Starter #14
Update, i recently changed my spark plugs and found out they were bosch platinums which are pre- gapped at .043! I put some Autolite 3923 gapped at .030. Huge difference, it pulls hard. Now i have 2 other problems, the SP61GT is still having boost creep and my idle is definitely not as smooth. I can hear the idle pop once in awhile and the car wants to stall more often.
Hardtop FTW
I still say get it tuned!
Escaped from infinite lag
i spent the money on the wide band and use my SAFC2 to setup the fuel man it made a huge difference i pickedup so much more power...
Moderator, l337 M0d3r4t0r
if you are going too rich there,, say 10:1 then you'll feel real slow in that area
1 - 18 of 18 Posts
