here is one i made awhile ago.
i like using the clutch reservoir off a honda civic because they are small, easy to hide, and relatively easy to find. reservoir is at the top and the one hose off the tee will go to one port on the rack and then you take another hose off the other end of the tee to the other port on the rack. fill the reservoir with fluid, bleed the system a little and hide the reservoir. this helps and is better than just ripping out your power steering system. let me know if you have any questions
