Hey SF, I'm in dire staits here.
My car started without issue until today, and now it will crank but not turn over. It turns out that the fuel pump is not getting power. I jumped B+ and FP, with no results. When hooked up to a power source, the pump ran, though i did not try to start the engine. I took the opportunity to completely replace all fuses, replace the EFI Main relay and replace all the fusible links, except for the 100A for the alternator. Still no power to the pump. Does anyone have any tips to pinpoint the problem? Any other relays that can be checked, replaced, or bypassed?
(If it matters, the fuel system is not entirely stock. The pump is a Walbro 255, without the 12V mod, and the fuel regulator is an Aeromotive AFPR.)
Edit: I'll also add that the CEL does not come on during or after cranking. And, after a quick check, it does not appear that there is power at the B+ terminal.
