No spark 1993 supra helpp!!
192 views 13 replies 3 participants last post by  minus500
#1 ·
Help, my car is a 1993 Toyota Supra GE 2JZ. She is right-hand drive. I had issues with the car before. It just all of a sudden cut spark before. It used to drive fine, but it used to be affected by the heat that I noticed. Like, if I idle for too long, then all of a sudden I hear a little misfire in the exhaust, and my car would just turn off. It would just basically start then stall, very smooth, quick, and then it always turned on after a while after trying. But this time, it just doesn't start. I have a code 14 and a 42. The 42 probably doesn't matter. I also had an issue with that on the freeway. I was driving, and all of a sudden my RPMs fell down. I didn't stall, but I was rolling to the breakdown lane, and all of a sudden my RPM moved back where it needed to be, and I had engine power. I changed the ignition control module and the igniter so far, and still nothing. I noticed I had no spark next thing im thinking is the ecu but not sure how to test it ?
And thanks in advance for replies and help
#4 ·
Have you looked at the distributor cap and rotor? Those would yield ignition issues. Probably worthwhile to go ahead and replace them as part of general maintenance even if they look okay unless you know they've been replaced somewhere along the line. Is there anyone you know locally who has a known good ECU you could throw in to yours? I believe a faulty ECU will present with those systems.
#14 ·
I'll send a update when I get to repairing it
Overall its all repairable right ? What do you guys think
As long as the board traces aren’t damaged and nothing gets damaged or shorted during the repair, you should end up okay. Honestly though, you’re already in need of a used or rebuilt ECU now, so taking a chance on this repair is really a “freebie” at this point.
