1 - 20 of 31 Posts
like i have said i searched for three days before making a new post.
I have an 88 N/a automatic. ive replaced the ecu and the coil. but when i go to start the car it turns over but refuses to spark. I also noticed i have no check engine light at all. Ive checked the bulb for it and the wires for it too. I have checked every fuse i can think of.
checked the efi fuse and it is fine
ive checked the fuse but what do you mean by circuit ive been looking through the tsrm this whole time as well.
check the efi fuse in side the engine bay, then check the ignition fuse to the left of the driver seat. that would cause a no engine check light as well.
when you bypass the fuel pump via diagnostic box does fuel flow?
Discussion Starter #8
did all the above
Discussion Starter #10
no i changed the coil though.
Discussion Starter #13
well the wires that go from the computer to the coil are fine so im guessing there is a different wire that s fucking with the ecu.
Discussion Starter #15
i did that lol. i have the whole wiring harness in my bedroom lol
Discussion Starter #16
okay i checked the whole wiring harness and its all good so what else is left to check??
I've only seen this twice, but check the +B trace on the ECU. You'll have to remove the cover on it to do this. The first resistor on this trace may be blown.
1 - 20 of 31 Posts
