1 - 4 of 4 Posts
after putting in the motor and wiring it up, i'm not getting any spark. the ignitor and its wiring are good, but there is no power going to the coil packs. also, the fuel pump relay is buzzing like crazy. anybody have any ideas?? thanks!
Buddy thought I had a NA
i int eh same spot as you right now i just jumped my fule pump but i got no spark eaather
ok, figured it out! it turns out that i installed the ground wire that is supposed to go on the intake manifold to the starter. now the car starts and idles for a few seconds, then shuts off. i'm thinking that either the cps wiring isn't good (the harness that came with the motor had the cps plug cut so i cut off a cps plug off of a spare harness and twisted the wires together), or the cam timing is off.
anyone had an experience similar to this??
oh yeah, by installing the ground wire to the intake manifold, the fuel pump relay buzzing went away.
1 - 4 of 4 Posts
