1 - 8 of 8 Posts
I have a 1987 Supra turbo and it doesnthave any spark to the plugs.
replaced the cam position sensor, but there still isnt spark...
what else is there that controls it and what should i check?
Thanks,
Nathan
Not ur jizz, not ur bizz
aight dude check this fuckin shit out.
there are some ground wires attached to your engine harness...its under the intake manifold around cyl 5-6..there are two of them, attach to the same bolt for the ground.
if its not grounded, ur car wont spark. simple as that.
if they are grounded and your car isnt sparking up..check your ignitor, replace it.
dbsupra said:
sure its not the cps wiring? i know you replaced the cps but 90% of the time its the wiring is loose inside the plug.
I agree 100% with dbsupra same thing happened to me i had to re-solder all four points make sure you take off that black plastic wire cover because sometimes the wires are chard their as well like mine where.
i have not put the cap on it, i was just trying to see if i had spark.
i will look into the grounds, and check the coil packs. :bigthumb:
thanks
1 - 8 of 8 Posts
