basically first you decide if you like any specific brand of speaker/amp or if you like the way one looks. If you hate the brand it'll sound worse to you. If you love the brand it'll sound better (within reason). It's a subconscious thing. I love JLs so they'll always sound best to me.
You picked Kicker solobaric 10s. I'm just guessing the s10l7 model for this discussion. You can get them in 2 ohm dvcs or 4 ohm dvcs.
2 ohm dvc let you run each one at 4 ohms or 1 ohm
4 ohm dvc let you run each one at 8 ohms or 2 ohms. However it's usually suggested not to run voice coils in series, the 4ohm and 8 ohm options respectively. Also you shouldn't mix and match subs (one 2ohm dvc and one 4 ohm dvc and run them together off the same channel)
Because you're getting 2 subs. You have a shit ton more options. Heres the JL audio tutorial on DVCs. Heres the tutorial on wiring the subs
Ok so now we have 2 subs and the options of 1, 2, 4 or 8 ohms if we run them to seperate channels on the amp. .5, 1, 2, 4, 8 or 16 ohms if we run them together off 1 channel.
The spec for the sub says 600w max rms so we want around that if not a little bit more per sub. So 600X2 = 1200watts RMS for the amp.
Now sticking with the Kicker brand amps around that power, theres the SX1250, SX900.2
The SX1250 is only 1 channel and its 625x1 at 2 ohms or 1250x1 at 1 ohm. So you'll need the 1250x1 @1 ohm. To get this you'll get the 2 4ohm dvc subs and run them in parallel and into the 1 channel. Giving you 2 ohms per sub and then the 2 of them combine to give you 1 ohm. Then the 1250w from the amp are divided among the 4 voice coils (2 per sub) and you get 650w per sub. Got it?
However. The amp itself is around $700.
So you either pick subs which take less power or maybe only run 1 sub with 600 watts and pick a new amp.
You don't want to run like 200W into a sub that says 600w for the rms. They're designed to take alot of power and move a big strong structure for big time sound. Too little power is like putting a inline4 in a school bus. It won't do nearly what it could and it's kind of a waste.
So there you have it. Run through that process and look at all the specs and plan it out well.
