1 - 18 of 18 Posts
Pic at post #15
how do i get my front bumper off, i am having a hard time with it, lol, i know im a noob to the DIY thing
The bigger question is why are you taking it off????
putting couple bigger things on, and felt like doing it myself 4 once
thanks,
as of right now i have the lights off, and a couple of the screws on the side connecting it to all the other panels, where do i go from here
Remove front end panel seal, remove upper retainer clips/retainer, remove lower center clips/retainer, remove the (front) fender liner screws, un-plug side and front turn signals and I believe that should be it. Be sure to get help pulling it off and maybe tape the corners of the fenders and lay a blanket down so you don't scratch anything.
Discussion Starter #6
ok, i have unbolted/unscrewed everything on the side/underneath the car, the part i am now haveing trouble on is these damn plastic screws right infront of my radiator cooling shiny plate thing, i took of the padding seal thing and under neath was these plastic screws, and no matter how much i turn, they wont come out!!! lol, what now?
Discussion Starter #8
you have to pull it out. if you screw those up dont worry they are relatively cheap.
lol, you must be one storng dude, cause DAMN! i tried to pull these things off and i couldnt even get them to move!! Any alternative solutions?
Get a pic and pull the center plastic screws out. Once the center screw is out, the outer sleeve just "pops out".
iSketch Master!
Yeah they are supposed to be kind of screwed out and pulled at the same time. They are a major PITA most of the time. I tried that way, and still broke some of them. The ones directly below that at the main inlet of the front bumper are a pain as well.
Alex
Working OT
Just get some roids man. Is that your trunk in you avatar got a bigger pic I like the nitrous bottle set up.
Discussion Starter #12
ya thats my trunk, the bottle when the carpet down is completely hidden, the way i like it :)
Take a picture if possible and post it up to give us a better idea.
Discussion Starter #14
ok, well i got everything off, took the old greddy 3 row off, and put the new 4 row on. I hooked up the drivers side piping and then when i went to go do the passangers side, i noticed it didnt quite fit, is this suposed to be like this?
Sometime different kit's have different pipe's (bends/cuts). That might be your problem.
iSketch Master!
Sometimes you have to tweak all the pipes a little. Loosen that one going to the turbo. it is a PITA, but sometimes you gotta rearrange all the angles they were originally at as well. On my friend Cisco's car we just went and got a new pipe welded up for there.
Alex
1 - 18 of 18 Posts
