1 - 7 of 7 Posts
I still have my stock dual-mass flywheel. Is there a local machine shop that can check and surface it? I am covering all of my options. Thanks.
Toyota do not require having them turned but I've broken a few rules and put it to the test, and so far All of them seem to hold up with zero issues.
Check your PM?
You Do Not want to have your run of the mill machine shop machining the V160's flywheel.
Send the flywheel to Southbend they have a special rig to do the V160's flywheel.
Is this machine shop in Southbend Indiana? Just want to be sure before I call. Thanks.
Check your PM?
I have about 90k on the original flywheel. The garage said that it appeared to have been turned once. It may be that all I have is a lump of steel now.
How did you put it to the test?
Bully
I think zum means south bend clutch
South Bend Clutch, Inc.
709 W. Jefferson Blvd.
Mishawaka, IN 46545
800-988-4345
574-256-5064
574-256-2568 Fax
1 - 7 of 7 Posts
