Hey I have a 1990 mkIII with the 7mgte and I'm currently dealing with a problem of boost loss at normal coolant temps. So when I cold start it (I let it idle like 1-3min before moving it because its cold outside right now) I get about 10-12 lbs of boost but only about -15-18 vacuum out of it but as soon as I see the temp gauge move I notice that I'm only full pulling about 5-6 pounds but I get about -21 vacuum at idle. Kinda at a loss as towards whats going on. So everyone knows what has been done its a stock turbo 124k with stock motor. Catless downpipes with open waste gate dump tube, cold air intake, Gates Blue timing belt with all front seals and the crankshaft timing belt pulley replaced.(found missing outer piece) I changed the exhaust manifold gasket, turbo gaskets and all the head studs for the exhaust manifold, did a set of plugs and wires with valve cover gaskets and both knock sensors due to having a cel for them. I also have the intake pipes under the hood changed because the factory one was in the way of the strut tower bar and it hit the hood but I have switched it back and I still see the same problem. Everything look good when I had the turbo out so I put it back in but I really am just not sure whats up. My next upgrade was going to be injectors,fpr,and boost controller to try and get a little more power out of it but now this problems has me worried to try it. Just unsure of it the vacuum pressures being off that much its a sign of a head gasket or piston ring problem. I do notice a little blue smoke if I sit at a traffic light then try to pull away but a friend told me that it just the valve guide seals because its not smoking all the time. I do have a brand new cylinder head and head gasket set for it but I have been saving money because I want to get the bottom end rebuilt and upgraded and I know when to have the block decked that plate in the front need to be done to with it. Hopefully someone else had this problem and could help me out. Thanks
