1 - 9 of 9 Posts
i am just running through my motor and im curious what the engravings on stock cams...is it 1-884 and 2-884?....then the intake had a number 1 and the ex had a number 3......im looking at stock cams correct?..
thanks
Jeff
what sensor would that be?....
if they were after market cams....would it have an imprint anywhere?
Moderator, l337 M0d3r4t0r
there is a nub where the cam pick up sensor is if you look on the intake of the head there is a sensor and on the cam there is a metal nub that passes it
ok im confuced...so what info am i gaining by having those metal nubs....if both stock and after market have em?.....
just trying to understand..thanks
Jeff
Not so boring anymore
i would say they're stock.. is there anything on the motor the would sugest otherwise (modded ecu, bigger injectors, turbo or something)?
Discussion Starter #9
yes..car had FMIc...chipped ecu....3in ss dp, HKS plugs, greddy gauges, trd oil filter....very well kept motor and the valve covers and crank pulley have been off....
1 - 9 of 9 Posts
