1 - 7 of 7 Posts
Hi, my driveshaft broke and took the O2 sensor with it when it snapped. Now I only have the wire coming from the driverside of my car where the 02 sensor is suppose to be. I got the new O2 sensor but can't find where the connection goes. Is it in the little hole where the O2 sensor wire is coming from? Please help thanks, Jason.
i think the one under the drivers side near the transmission tunnel is plugged in under the driver seat. you'll have to remove the seat and lift part of the carpet out of the way to get to it.
you should see 4 plastic covers on the metal base of the seats. remove them to get to the bolts. remove those then unhook the 2 connections under the seat. then be careful removing it out of the car.
Use a small flat screw driver. Along the sides of the plastic covers are notches you can stick the screw driver in. Apply pulling pressure to the outside of the the covers, then up. There are clips underneath you have to release. Once you get one off you'll see what I mean.
1 - 7 of 7 Posts
