1 - 20 of 23 Posts
boosted for life
Just a question I keep going through o2 sensors and dont know why. So how far down the exhaust should it be im not running stock turbo and right now its right around where the stock o2 sensor would be. Im just wondering if its to close to turbo.
This might be dumb is the stock o2 sensor the only o2 sensor we can use and does any one know where I could get one cheaper they are exspensive. Thanks any advice would be very helpful
boosted for life
wiring is good. It keeps running really rich like crazy it blows so much black smoke but when i change the o2 sensor it runs great. and yes i have a safc and 550cc injectors the fuel is turned down it only runs rich when the o2 sensor goes shitty besides that the car runs great. I just cant figure out why o2 sensor keeps going.
I'm pretty sure i have read in previous posts that the mustang sensor can be used.
boosted for life
I read that two but was not sure can any one confirm this what year make and model and is that 4cyl 8cyl or what
Big HP = Big Downtime
nice don't see many windsor people on here.
anyway usually if your o2 sensors are failing it means your car isn't running right. If its running very rich its fouling up the sensor until it can't read anymore. Is it tuned up and running properly?
Not ur jizz, not ur bizz
ladmo said:
When you get shitty gas milage, your running really rich (i.e. black smoke comming out exhaust), or you get code 21 telling you its bad.
when you get 230 miles a tank..thats when
as for code 21, yes its an indictor engine light for the o2...only really happens when it isnt plugged in :)
Play nice guys and stay on topic! and check for IC leaks and a good ignition system cause running rich can also damage your 02 sensor... aight peace :chicken:
Savage Member
I get 220 Miles per tank...with 550's/lex.... Does this mean I need to change mine? I haven't ever so...............=)
1 - 20 of 23 Posts
