1 - 7 of 7 Posts
I have a stock MAF with an SP63. I have seen as high as 99.9%. On the dyno at 526rwhp I saw 97%. When I was BPU+ I think 87% was the highest I saw.
Hope this helps, Steve
I saw you on 580 on Berkle before right? GReen 97 with Euro hood?
anyway, I'm OBD1 but I dont think there is a difference. mine reads around 78% at WOT with APexi AFC
BPU I've gotten 43.x lbs/min. APU at 13psi I've gotten 47.x lbs/min on a very cold day.
43# is the highest I have seen in my case at BPU as well. It goes negative after that.
For those reading this thread I am taking about the MAF #/min flow rate and NOT the percentage that your AFC reports. The AFC numbers might be interesting too but I am not sure how comparable they are.
Grant from talking to Steve97TT 43# translates to around 400 bhp without transmission loss numbers. Did you ever dyno your car at BPU?
I think I got the latest version of obd-2.com software to work so I am hoping to see if 43 number can be exceeded at BPU.
Hehehe nice to have a portable dyno huh ;-)
-Kapi
Kapi,
My obd-2.com software would do the same thing, go negative after 43. I now use a Palm Pilot logger that doesn't do that.
I dynoed 383 straight BPU + a cam gear (untuned set to -3), a 1/8" boost leak, 94 octane and no cooling.
Grant,
I just tried the new version of the software and the highest I have seen 43.164 lb/min. Using the calculator on Steves page that translates to 470 crank and assuming 20% auto loss 376 rwhp ;-). If it wasn't for the nasty 91 octane gas it could be higher.
Gotta love OBD2 when you can estimate your RWHP using it ;-)
So now that I know how slow I really am time to upgrade.
-Kapi
1 - 7 of 7 Posts
