I have converted from OBDI to OBDII. For some reason my car did not come with heated O2 sensors, but pretty much every other car did. My question is, could this mess with being able to control my A/F's?
I am running a MAP-ECU V2 with and O2 simulator, and a Zeitronix WB that has an analog output, and then a single stock O2 sensor in the downpipe. I have tried plugging these into the 3 oxygen signals into the ECU, but it doesn't do anything.
At idle I can't get it to run anything but 12.7, no matter how much I lean out the mixture. I need to get this to pass emissions and a 12.7 just won't cut it.
I need to know if the OBDII ECU also needs to know if the O2 sensor is even there by sensing the heating element.
And then there is the EGR temp sensor. On most vehicles I have worked on, this will cause a loss in gas mileage and cause the engine light to go on. Is that the case for this?
