odd miss (please help me solve this)
486 Views 5 Replies 3 Participants Last post by  bahraini_zupra
the story: i went to opening weekend at great lakes dragaway, this being my first time running AEM at the track... ran some decent times and some hideous ones
the car:
'95 supra turbo auto - stock twins, bpu with AEM EMS, UEGO, front mount, cam gears (100 motor octane fuel)
the problem:
@ roughly 3000-4500 rpms in the top of 3rd gear the car approaches 20+ psi
at this point i feel a cut (somewhat like a rev limiter)
diagnosis: AEM Log showed that the car ran extremely off the scale rich (but adjusting the fuel map did not improve condition)... my plugs are gapped down to .024 since i do not have an upgraded ignition... checked plugs, they look well, a tad bit black, but far from white
question:
what is causing this? am i "blowing out" the spark? is it a tuning issue?
thank you all for your help
If you're BPU isnt the spark plugs gapped down too much? I think it should be closer to .030 versus the .024 you have now.
its gapped down that much becuase i am running AEM EMS, which changes the ignition set up to waste spark (so essentially im losing half my spark)
im using NGK 3330s
i dunno but ppl got bad luck using 3330 they usuwal go with 6097 and i think thats ur problem maybe if its not the coil hope that helps .
