1 - 4 of 4 Posts
Anyone have an idea on what's causing this or how to fix it? This is the driver side tire. The passenger side is not doing this. The car is on megan coilovers.
That appears to be the inside of the tire. Seems you may have some negative camber in your alignment. If it bothers you, go get an alignment. Possibly some Toe as well.
Very Senior Member
Front or rear?
Looks like too negative on camber. Also check wheel bearings - they go out on the driver side first.
It's the rear
1 - 4 of 4 Posts
