Curt,
Could I get the prices on the following items:
#04465-14081
#04945-14010
#04947-24030
Also, I need to know if part number 47715-24010(frt cal. pins) are the caliper guides that are bolted to the caliper mounting bracket. These would be item's that would seize if not properly kept. There are two per side. If this isn't the part number for those, do you have it and are they available?
I couldn't find the part number for the little plastics clips that snap into your interior trim pieces covering the screws that hold the trim down. They are about an
inch (maybe less) in diameter. Would these also be available?
Shipping would be to area code 49505.
Discussion Starter · #2 ·
I forgot that i also need the clips that are fastened to the inside of the rear bumper that you mount your liscense plate too. I don't know if this the correct part number or not.
#52121-24020
If not, do you also have those in stcok?
04465-14081 Pad Kit, List 58.21 Cost 42.61
04945-14010 Shim Kit, List 36.20 Cost 24.14
04947-24030 Fitting Kit List 28.02 Cost 21.57
47715-24010 Pin, List 7.29 Cost 5.62 Ea X 4
47769-50020 Bushing List 3.94 Cost 2.96ea X 2
47769-50010 Bush, List 3.94 Cost 2.96 Ea X 2
90950-01503-c0 Plug, Hole List 2.23 Cost 1.65 Ea
52121-24020 Bracket, List 4.12 Cost 3.04 X 2
