I have the same swap done on my supra..jap motor..
Well oem LSD won't fit the 5speed Rear End casing..you will have to purchase the whole rearend chunk(casing) with lsd internals..
Also your 5 speed tranny with not hold up much longer..pretty weak gearbox..I went with 6 speed and welded my rear end (original 5 speed differential)...don't plan to weld it because turning corners causes tire wear..
