I will tell you why you should go original. First of all, When you have a body kit, your going to get "Body Flex" when driving the car, therefore you need a very flexible material that makes up your body kit. I have seen replica body kit's go bad after a couple thousand miles because of "body flex", the paint ends up cracking aka *spider web* and the paint starts to chip. Also, the body kit will flex and won't be proportioned with the car properly. I know Original Veilside Body kits can be bent like a twizzler! Therefore the paint won't crack, it will stay flush with the car, and if you get it molded, which most people do, the results are Phenomenal. It also all depends how much you drive the car, weather conditions, etc. Personally, I like the best for my car.
Just my $0.02
