First off who on here has done it successfully. I saw one come up in the FS section recently. The LSX and Ford guys have been doing this for a long time with good results and the machine work isn't really too expensive. It looks like you can get ~0.2L out of offset grinding the crank on a 2JZ. Combine this with a larger bore and you could be close to a 3.3L.
So, are you severely weakening the crank to the point that your negating any benefit you would get from the additional displacement? Is there anything special besides the machine work and custom pistons and rods? Does the block have to be "notched" to accommodate the crank? Would you be able to rev high with this set-up or are you going to be limited?
I'd like to hear what you guys have to say so feel free to post.
