I feel your pain! On my car the high beams were in the lo beams. All sorts of shit ass wiring with the stereo. Bad wiring on the safc install. You name it I've been there and I'm sure I have more to uncover! GOOD LUCK!
I totally agree with Larrabee, start over cut all that shit out there and solder new wires and heat shrink them and be sure none of em are grounding out. That sucks
Larrabee said:
my friend had the same problem with his TT. he cut the wires alittle further back and soldered new wiring and clips on. it solved the problem.
Congrats to Grannas for running an impressive time with his 2jz/T56 magnum setup.
7.256 @ 200.92
1.168
3.190
4.786
152.52
6.133
Huge accomplishment. His IG stated he was using a 88mm turbo when he did the record pass, and now he has on his 98mm turbo💪💪💪
He is using the GR1000F version of the...
I'm looking for RHD MK4 Supras being imported. My end goal is a Single Turbo 6MT Supra. What's the best Supra to buy while considering prices? Buy cheaper and build, or wait to buy an original TT 6MT Supra? Any input is valuable! Thanks!
So I've been keeping watch over the past two years (as many others have..and for longer) for hybrid turbos which retain the sequential operating system and offer significant hp gains.
Well Stu Hagen, King of the Sequential twins (not necessarily "stock" sequential twins in this case), has come...
Hey guys i was just wondering since im doing an Aristo GTE swap on my rhd MK4 Supra will i still need a longer wiring harness? I know for lhd vehicles you do but does this transfer over to rhd also? thanks for the replies have a good day!
Okay I’m about ready to smash my head into the wall. Can anyone tell me if there is anyone who makes a different ratio ring and pinion for the 200mm diff. I recently took the diff out of my car to fix a leaky seal. When I bought the car I was told it was a full turbo conversion but I felt that...
