Have you replaced your valve-stem seals?I can't figure out why I'm using up so much oil. I did a compression test and it came out between 175-185. Leakdown was approxiamtely 11%.
No I haven't. This is a completely new motor with only 3K miles so I wouldn't expect any issues, but you never know I guess. I purchased a borescope which I'll have next week so I can check out what's happening in the combustion chamber, valves etc.Have you replaced your valve-stem seals?
6% leak down would be very good numbers, but not common with production motors from what i have read online. Anything up to 20% is considered ok and up to 10% is very good. I've spoken to a couple of reputable Supra shops and they stated 10-12% is pretty common for a completely rebuilt motor.I thought you wanted your leakdown to be less than 6%? I could be wrong.
Compression seems fine. Valve stems need replacement?
i thought that might be the case, but the plugs turned out clean.sounds like a blow-by issue to me?
I'm suspecting lack of race fuel at the race track caused the cylinder to run too hot hence the detonation on the valve relief. My tune is suppose to be fine for 94 octane, but I think a bit of race fuel may have avoided this problem. Secondly, I think there may have been a bit of dirt in the oil as there was a bit of premature wear on the bearings. We've polished the wear out and replaced all the bearings. It's possible that since the block was new there may have been a bit of machining material left in the oil ports and as soon as I fired up the car the bearings got the worst of it.woa, what would cause something like this?
glad to see you found the source of the problem and thank you for sharing with the community.
