So I’ve looked at the other thread that has information on how to upgrade the oil cooling for the engine and I’m planning to do that, but I was wondering about some of the other components as well. Specifically the transmission and rear-end.
I’ve seen coolers for auto transmissions, but not so much on manual transmissions? I also know that I’ve seen them for the rear-end as well. I can’t recall seeing them on a supra though, I’ve seen older cars with the rear-end ones.
I guess specifically I’m wondering if there’s a real need for them and if so, what size cooler. Also, would you need to use a pump? I’m guessing yes, but since the oil is cooling spinning objects, maybe there is a circulation effect that makes a pump optional?
Admittedly I probably won’t be tracking the car that much, but given the choice, I’d rather have the car setup to do that rather than not. Seeing as you’d have to make fittings it may make adding a cooler a pain, but I guess at the very least it would be nice to know
