1 - 4 of 4 Posts
Powderin my balls since07
I bolted the turbo to tha mani, the return line to the block, but the oil feed line won't go on for the life of me...did i have to do this first? its the 17mm bolt with the copper washer near the solenoid on the turboside of the block...
it's a bitch is if the line gets bent at all...
I do it first since it's the hardest part...
90T
If you haven't already, it helps to put a bit of assembly lube on the copper washers so they don't keep falling off as you try to position the line.
^^lol i learned that after loosing it and spending close 2 a half hour tryna find it! so its easier to put it on first...i just about have the turbo off again so i'ma try that 2nite...
1 - 4 of 4 Posts
