1 - 3 of 3 Posts
im doing the 1/2 na-t here shortly.
i have a couple things i need cleared up regarding the oil feed.
im using the plugged oil pressure port near the engine mount (right next to where the return line goes on the GTE).
im sure it is, but i would like confirmation that this port does in fact supply oil pressure.
more importantly, what size thread is this hole? i had the fitting looked at and someone told me it was 1/8" NPT, but i thought our cars had BSP (not really sure). i need to know what size so i can order the right fitting to go in there (duh).
thanks a lot. :)
100% Eurotrash
My 1/8" BSPT to NPT adapter does not fit in that hole....so I'd have to say that rules out BSPT. I don't know if that hole supplies oil pressure.
Personally I would tee off the oil pressure sender hole...that's what I did for my civic.
the NPT side doesnt fit either?
i could go the Tee fitting route. i thought this would simplify things and leave less places for it to possibly leak.
i still want to know the size of the plugged hole, but what size is the oil pressure sending unit just in case?
thanks!
1 - 3 of 3 Posts
