1 - 2 of 2 Posts
Flying Dutchman Pilot!
Hi guys. I just purchased my auto 94TT and I am looking to do some general maintenance on it. I searched the best I could but it appears the search function has its bugs.
I just did a boost leak test. The first try I brought the pressure up too fast on the regulator and I popped the oil fill cap. I released the pressure and tried again. I can hear a constant hissing coming from the oil fill cap at just about anything over 3-4 psi. I just want to verify this is not normal and the cap needs to be replaced. Also if it is bad should I get a stock cap again or is there a better aftermarket cap?
Other things on my list are:
6097 plugs
PCV valve, grommet and hose to intake manifold
Both TSRMs
Valve stem seals(little bit of smoke on cold start)
A few other odds and ends not really maintenance related
Any other common things I might want to add to the list??
Discussion Starter · #2 ·
Nevermind, after talking to a few people I realized my boost leak test was pressurizing the pcv system and there is no pressure(from boost) in the system during normal boosting.
1 - 2 of 2 Posts
