1 - 14 of 14 Posts
SuperWhiteNinetyTwoMeat
Will assembly lube leave a whitish-grey goo on the bottom of the oil filler cap, or is there anything else that will cause goo to get on there, besides a bhg?
Well the thing is I did a HG swap about 1000 miles ago, and used a bunch of assembly lube on my camshafts. I used some expensive Castrol GTX oil so it certainly not cheap.
Did you touch the bottom end/oil cooler at all? If not then it is probably residue from your previous BHG. I had the same problem. Two oil changes and everything goes to normal.
bhg agian perhaps... do a compression test now!
Look anything like this?
Oil cap:
Oil line coming off valve covers:
Well it just started collecting, so no its not nearly that bad, its just that I did not get coolant in my oil on the first bhg.
JZS161 Aristo TT
This is BHG goop
Clean the oil cap for F sake :rant:
*Edit* to be 56k friendly :rockon:
JZS161 Aristo TT
Jaguar said:
1G-GTE! :rockon: Is it yours?
Never going to down grade would have brought fixed sold but it was POS car ant going to pay $1000 for a rusty slow puss bucket
These engines are a bearing eater in this state
Republican
Someday, I will rock the 1g-gte.
JZS161 Aristo TT
First *a70 i drove was a 1GGTEU
I asked the owner what was wrong with it :lol:
1 - 14 of 14 Posts
